RCU Forums - View Single Post - GP Extra 300 .40 size what engine?
Old 07-18-2005 | 06:35 AM
bubbagates's Avatar
bubbagates
My Feedback: (32)
Default RE: GP Extra 300 .40 size what engine?
2fun,
A 91 2 stroke in the plane will be way overkill. The size prop you will need may even be a problem with the ground clearance not to mention things like airframe vibrations, firewall reinforcement, weight, wing loading, etc...
If you do the 61 then you will have a good match with nore than enough power
What prop are you using on the 46? To little prop or too much prop can also be your issue
