RCU Forums - View Single Post - Walkera Dragonfly #36
Old 07-18-2005 | 06:45 AM
aurora799
Default RE: Walkera Dragonfly #36
ORIGINAL: rotarypower3
It can charge up to 5amps. Can't remenber what the minimum charge rate is off the top of my head, but you obviously can program your own charge rates in. Except for lipos, which won't go higher than 1C.
Oh, I meant the input power to the charger. It needs 12v input right? Do you just run it on a battery or do you have a power supply for it?
I guess if it is charging a 11.1v batt it would need about the same amount of current for the input as it would for the output?
