RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 07-18-2005 | 11:11 AM
  #2726
AcroJo's Avatar
AcroJo
Default RE: U Can Do 3D
jlkonn, with the YS 110 I have 4 degrees right thrust. Its off to the side as far as will allow, but there is still a slight angle to my cowl to center the hub. Can't have it all I guess.
Raj, picked them up at the hardware store in the plumbing section. They are to secure 1/4 inch PVC tubing in place. Its what they use on the water line to a refrigerator. They are called P clips. I drill and thread my motor mount and do not pass through the mount arms with long bolts and lock nuts. The bolts bite into the mount arms fast and have never come loose. With the shorter bolts it left a threaded hole opposite the bolts so I just secured the P clips on the other side with short machine screws. Nice and tidy. Joe
