RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 07-18-2005 | 12:27 PM
  #2736
AcroJo's Avatar
AcroJo
Default RE: U Can Do 3D
ORIGINAL: c016Y
And the end result was not roll tendency?
Also.. with the removal of surface area.. will it still knife edge loop? Currently.. it will pretty tight.
It did a great job on eliminating roll coupling. Mixing will have the same results. The rudder has an 80+ sq. in. area and you won't notice the 30 sq. removed. I felt that the high profile of the rudder was what caused it to lean or twist.
Yeah Stoney, the flames were cool, but the visibility factor was worse than when it had the blue on it. I struggled with the blue on overcast days. I could see it well now. Joe
ID:	298596   Click image for larger version
ID:	298597   Click image for larger version
ID:	298598   Click image for larger version
