RCU Forums - View Single Post - Firebird Scout
Old 07-19-2005 | 12:05 PM
laaf2005's Avatar
laaf2005
Default RE: Firebird Scout
Do you know where the COG is suppose to be on the plane? From what I can tell the COG of my plane is between the landing gear and the place where to boon meets the fuselage. If you look under the plane you should see a place where part of the body indents just behind the landing gear which is where my COG seems to be. If you can let me know it will help a lot in figuring out if it is balanced.
I am charging my battery now for a test flight. The field I will be in is not big so if it does start to fly how can I quickly land it as soon as it starts climbing? Or is there even a way to?
