RCU Forums - View Single Post - Fuji 64A vibration
Old 07-19-2005 | 03:04 PM
RichardGee's Avatar
RichardGee
My Feedback: (157)
Default Fuji 64A vibration
I am running a Fuji 64 on a Kangke Laser 2000. The engine has the optional long prop hub. I am running a balanced 22x10 Pro Zinger.
Every club member at my field who has helped me in the pitts during run-up has commented that the engine seems to be producing a tremendous level of vibration.
The engine was flown very rich yesterday and the aircraft sustained a broken muffler mount 'stay' and broken cowl mount blocks. Upon leaning the motor to smooth its running, 2 club members felt the level of vibration (even with clean, lean running) was excessive.
Upon returning home, I rechecked propeller balance and used a dial indicator to check prop hub/crank run out. Prop balance was perfect. Run out at the spinner tip (Tru Turn spinner) is approx. .005". The same run out exists at the prop bolt shank. However:
Run out on the rim of the prop hub (prop flange) is approx. .015" indicating the prop hub itself may not be true. However, it would seem the spinner tip and prop bolt would be the ultimate measure of run out.
I mounted the standard short prop hub and observed almost identical measurements.
However, these are all STATIC measurements. Since like every other Fuji 64 I have seen, mine experienced contact between the flywheel and magneto throughout break in, it makes me wonder about the Fuji's crank run out during operation... is the crank shaft ill-supported leading to excessive run out (wobble) during high speed running?
I have no way to knowing if the measured run out is excessive; no way of knowing what the long prop hub is doing AT SPEED; and no way of knowing what consitutes excessive vibration except to say that every time I have flown this plane, SOMETHING ends up broken due to vibration.
The airplane was flown once today. Vibration noise (resonance) coming from the airframe is excessive and unnerving. The tail stays on the aircraft are continuously loosening, the cowl mounting holes elongating, the cowl itself is being destroyed with cracks, and servo output linkages are showing vastly premature signs of wear. The vibration is so bad, I believe the entire aircraft is at risk of catastrophic in-flight failure.
The engine is very solidly mounted to a 3/8" hard ply firewall. Please advise.
Richard Geertson
