RE: bow ties?
Ive actually put worn Bow tires on the front of my Evader. My thoughts on that are this...They Grip very well, and IF...IF your car is balanced properly they will work great. What I found personally was that the front wouldl ift off the ground just a lil, then when it would touch down again the turn would be to much...I mostly ran on grass so the traction was to much ( I thought). I found that I couldnt control the steering, it seemed very erratic and was hard to keep straight. Also, I had a few broken parts that I found after that, so that ay have been the issue. It looked cool, and I think that if you had 2 sets both front and back ...brand new I think that it would look pretty sharp.
Speaking of tires, When you guys say that those Road rage tires or w/e they were called are the best....thats rear tire....what would you run for the front tire?
