RE: Tmaxx Tyres on MT2?
There are only two ways that I know of one is to use adapters from Renegade but you will need a good supply of axles.
The other is Poor Judgement's way which, so far is the best way.
If you are new to this you probably should stick with stock. The Imex tires will work but as far as wheels go make sure that the new wheels have the same backspace as the stock ones.
