ORIGINAL: kingnoddy
How often should I change the foam air filter ?....Ive run nearly a gallon on the original & its black.
You should probably clean it and re-oil it after every run or two. Replacing it every gallon or two isn't strictly necessary, but it's probably a good idea.
