RCU Forums - View Single Post - Fuji 64A vibration
Old 07-20-2005 | 09:22 AM
Bax
Default RE: Fuji 64A vibration
IF the crank has too much wobble, it may need to have the bearings replaced. They may have too much clearance. Hard-mouning large, single-cylinder gasoline engines is also not recommended. They really should be soft-mounted so that less stress is transmitted to the airframe.
You may wish to send the engine to us for evaluation of the crank bearings, crank, and prop spool.
