RE: gas fuel with glo plug no ignition
Hi,
So, cutting to the chase here, it sounds to me like a mixture of 50% E-85 if you can find it, 50% regular gas, and your normal oil mix would be a good way to go???? (My closest source for E-85 is over 200 miles away, so I'm wondering if cutting it like this will result in a good mixture. I also don't want to modify my carb for a higher alcohol mix.)
Aeronut: Did you get the pm I sent? Please e-mail me.
AV8TOR
