RE: gas fuel with glo plug no ignition
Get a spray can nozzle that has a tube on it, like carburator cleaner. Use that nozzle & tube on a can of Ether base starting fluid. Bubble a small quantity of the starting fluid into the Gas/Alcohol mix, it doesn't take much. It will all go into a stable solution and the Ether will help ignition.
