RCU Forums - View Single Post - i feel so dumb..
Old 07-21-2005 | 08:04 AM
ICrashThings's Avatar
ICrashThings
Default RE: i feel so dumb..
yea dude, when u get that 2.5, you dont adjust it when u first get it. You run it on the stock settings traxxas gives you, then after your 3rd-4th tank you can slowly adjust the high speed needle. Usually you would give it more lean because the traxxas settings are rich....or should be.
I have the Traxxas 2.5r in my nitro 4-tec and it runs great. Also make sure you break in the engine the way traxxas tells you or you will have problems.
