RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 07-21-2005 | 11:45 AM
  #307
DennisF
Default RE: E-FLIGHT BLADE CP
Hi all
Been reading the post on the blade cp got mine last week i have flown it and called tech support for the answer to this problem tech support had no answer and never heard of a blade doing this , so here's my problem when first taking off i only get it to break ground about 12 inches then i set it down a few times and take off with the same results then all of a sudden it just sky rockets up i am used to it now but at first it caught me off guard anyone else having this problem or know what is causing it no bind in the swash plate and i see the servos move for pitch control also the main motor pulses with trim set to minimum and the t-stick all the way down another thing is no matter what i have set the center 4in 1 pot to in terms of decreasing gyro yaw as tech support indicated the bird keeps pushing to the right i have to hold the stick way over this after it is out of ground effect any ideas or help is appreciated as tech support has no idea's.
Rgs
Dennis
