RCU Forums - View Single Post - A Beginers Guide to RC.
Old 07-21-2005 | 12:02 PM
  #62
Lightfoot
Default RE: A Beginers Guide to RC.
If you buy something like a Futaba Skysport, you will get a 4 - channel transmitter and a 7 - channel receiver. But, that is not the issue. Using 5 servos in this case means that there will be 2 servos for the ailerons. You can connect both servos with a Y - connector and plug it into the receiver and still only be using 4 channels of the receiver. If you get a computer radio, it will allow you to use 5 channels of the receiver but that will be extra expense to accomplish the same task.
