RCU Forums - View Single Post - Low Bounce/Shock Absorbing Wheel Assembly
Old 07-21-2005 | 12:17 PM
DTB's Avatar
DTB
My Feedback: (15)
Default RE: Low Bounce/Shock Absorbing Wheel Assembly
ORIGINAL: flycatch
Can someone explain to me what is the difference and benifits of these wheel designs?
In theory, they are suppose to not allow the plane to bounce or reduce the bounce on landings. Since this is the beginner section, most trainers bounce not because of the wheels, but instead because of the landing gear itself. Low bounce tires can be used if this problem is big. Normally, working on your approach and landings reduce the bouncing of a trainer. The tires are made from a shock absorbing material. I've seen many new pilots change over to low bounce wheels with no difference noted. I mentioned eariler, practice will reduce this tendancy.
