RCU Forums - View Single Post - Plane Balancing Idea???
Old 10-19-2002 | 03:23 AM
Tailspin Terror
Default Plane Balancing Idea???
What I do is build a hardwood block, on the CG of my model's wing. I then screw an eye bolt into the block, on the CG. In the case of low wing models, I hang the model upsidedown, from the ceiling and then I'm able to balance the CG, fore to aft and laterally, wing tip to wing tip, all in one shot. Hope this helps you out.
