RCU Forums - View Single Post - runnig st with two speed
Old 07-22-2005 | 06:44 AM
gerwen's Avatar
gerwen
Default RE: runnig st with two speed
ORIGINAL: ThunderbirdJunkie
it won't work because 2nd gear engages at a set GROUND SPEED.
Pretty much functionally correct, but not entirely accurate.
Really it engages when the tranny spins up to a high enough rpm. Without first gear, your tranny won't spin.
See if you can adjust the shift point down to where it's engagaged all the time. Other than that it's probably worth your while to replace the spur.
