Pull-Pull Funtana - HELP!
If any Funtana owner out there bashed the rudder / elevator servo location to fit inside the plane along the CG please let me know : "Is it worth the trouble?" and "Where and how did you exit the pull-pull cables" ( no experiance with this set-up on an ARF) also how did you hinge the elevator halves together?.
I am trying to avoid adding extra weight to the nose using the recommended set-up and CG using a Saito 100 for power. Any and all suggestions are welcome. Also pictures..being worth .....would be great!. Thanks- mikel-T
