RE: 1.60 DZ Question
Check to see that the check valve in that line is screwed together tightly. It is also possible that the throttle barrel seal is leaking and allowing air to get into that line.
Is the engine running OK at full throttle? or is it trying to go lean? If it's running ok don't worry about it.
