RCU Forums - View Single Post - Parkzone P-51 Preflight check list and Launch tips
Old 07-22-2005 | 10:39 AM
L0stS0ul's Avatar
L0stS0ul
Default RE: Parkzone P-51 Preflight check list and Launch tips
Added items by The Marsh Man:
1. Be aware that that the wires for the ailerons can corrode over time and should be checked and lubed. Lube them now with a graphite or other lube that should protect the wires.
2. If the wires do corrode, replace them with a guitar wire. The guitar wire has a higher nickel content and is more resistant to corrosion. The ultimate replacement would be stainless steel wire if you can find it.
