RE: Official Nitro Evader ST Thread
Ok here is what is going on...
I have the high speed perfect, runs awesome.
Problem is idle and braking.
The idle adjust on my remote is slightly high, so the servo is not perfectly straight, its always holding the throttle open a little.
When I pinch the fuel line the engine revs up a few seconds after.
It is constantly vibrating the clutch bell, as if it is slightly engaged, and sounds like it is running too high.
Yet when I hit the brake, it stalls out, I can't hit the brake more than half or it stalls.
Let me tell you this tho, I have the HSN dialed in tight. I was poppin so many wheelies I need to loosen the slipper! Absolutely crazy!
Oh it is sputtering a little bit when it changes speeds, like idle down after high speed run. What is the default setting for the LSN? I have gotten answers on the high but not low, and I just realized how to set the idle by looking inside.
Thanks for the answers again guys.
Oh btw, has anyone moved their battery box up in front of the receiver box? I figure it will put more weight to the front for better steering and stop trashing it when I pop wheelies. I think it would give better weight balance.
