RE: CEN Help ME! CT4S
Slingdirt, Out of the box the car is setup for high top speed. You can get more bottom end by cutting about 3mm off the clutch spring and then bending a new loop and reattaching the spring. This will allow the engine to engage at a slightly higher R.P.M. This will give you a slight increase in bottom end power. If you want a big difference in bottom end CEN Racing also offers a Competition Drive Train kit which reduced the overall drive ratio of the drive train for more bottom end. This kit will reduce the top speed of the car slightly.
