RCU Forums - View Single Post - Step by step converting Poulan 25cc FL trimmer ($25 on e-bay)
Old 07-22-2005 | 10:52 PM
RysiuM's Avatar
RysiuM
Default RE: Step by step converting Poulan 25cc FL trimmer ($25 on e-bay)
Step 4.
It will be easier to cut the engine if you remove the cylinder. First remove the back plate using 5/32 hex key. You need access from the back to disconnect the crank.
Two hex screws are quite tough. You need strong 3/16 hex key. I got 10 PC. COLOR CODED SAE T-HANDLED HEX KEY SET from Harbor Freight (ITEM 37861-4VGA) for $5.66. The best deal in the town.
Now protect interior of the engine from the aluminum dust. I fill the crankcase with paper towel and then tape it with blue masking tape.
ID:	300452   Click image for larger version
