RCU Forums - View Single Post - help with balancing nexstar
Old 07-23-2005 | 01:15 AM
ho2zoo
Default RE: help with balancing nexstar
Easiest way is to buy some of those stick-on lead weights. Many companies make them, like Du-bro, Great planes, Sullivan, etc. Cut off a chunk, stick it to the wood inside the engine compartment, and then check the balance. When you get the balance right, run a line of CA glue around the weight where it contacts the wood. This is to make sure it stays stuck on.
