RCU Forums - View Single Post - help with balancing nexstar
Old 07-23-2005 | 12:39 PM
britbrat
Default RE: help with balancing nexstar
ORIGINAL: YNOT
-----DO NOT REBALANCE THE PLANE. IT IS NOT TAIL HEAVY!!!!!!!!!!! IT IS PERFECT!
----- Do NOT add weight to the plane. It is not out of balance, the person telling you this is just unfamiler with the NexStar and I don't care how long they have been flying, it doesn't need nose weight.
----I'm right and they are wrong on this one.
You're only right if this is a NexStar Select. If it's the ARF it could be configured quite differently than the Select. For example, it could be powered by a lighter engine than the OS .46 FXi in the Select, thus requiring balast.
