RCU Forums - View Single Post - Pull-Pull Funtana - HELP!
Old 07-23-2005 | 03:25 PM
FallingWithStyle's Avatar
FallingWithStyle
Default RE: Pull-Pull Funtana - HELP!
A F90 with a Saito 100 will balance just by moving the battery around. You don't need a pull-pull rudder or putting the battery in the nose unless you use heavy (2oz) servos in the tail. Even then try moving the throttle servo up front first. The shorter linkage is better anyway.
Clark
