RCU Forums - View Single Post - RCV 120 SP Break In
Old 07-23-2005 | 10:55 PM
realwiz
My Feedback: (9)
Default RE: RCV 120 SP Break In
Is it possible the 15.75x13 prop is not giving enough flywheel action to keep the engine running at low rpm? Are there any other 3 blade props you would recommend? I can't go much larger than 16 inch diameter.. I got the max RPM up to 5000, and flew my airplane for the first time. The plane is designed for a 90-120 4-stroke the RCV just barely got it off the ground.
