RCU Forums - View Single Post - WHAT PROP FOR HIMAX 2816-1220 on Mini Funtana???
Old 07-24-2005 | 02:28 AM
Sunday3DFlyer
My Feedback: (28)
Default RE: WHAT PROP FOR HIMAX 2816-1220 on Mini Funtana???
Hey thanks!
I have built tons of electric airplanes. This is one of the first times I was not sure about. The paper [link=http://www.maxxprod.com/pdf/HC2816-xxxx.pdf](Here is a link to the paper)[/link] they give you with the motor has a graph you have to decipher. At 11 volts and a 10'' or 11'' prop is off the entire graph showing that it will pull A LOT of amps. I called up MPI, and the technician quoted "Do not use the Slo-Fly prop because they will draw too many amps. You will need to use APC E series propellers in the 9x5 area."
O well, Electric is just a trial and error process...
Thanks again for the information.
-Chris
