RCU Forums - View Single Post - saito 82???
Thread: saito 82???
Old 07-24-2005 | 08:14 AM
wind junkie
Default RE: saito 82???
Interesting. I agree 2 strokes are cheaper and DO spool up faster (they can rev from 5K to 17 K in the same time a 4 stroke revs from 4K to 10K) however, you'll never see the plane actually MOVE faster than the 4 stroke powered one -- just the opposite. You get more "whine" and less "pull" with a 2 stroke. The props are smaller, and the torque over the useable (hovering) mid RPM range is less with a 2 stroke.
Concerning durability: After crashing a 4.5 lb tufflight 4D well over 100 times (many, many of these resulting in buried engines) with an OS .46 FX, I can attest that this motor is a good durable one. Two other friends I fly with had similar experiences. The only issue I ever had with the OS was the carb screws had a tendency to fall out, but that was solved by some loc-tite. HOWEVER, after I put a Saito .72 on the same plane, I was pleased to find that it too could survive crashes. And the best part was that the carb is in the rear, so it wouldn't fill up with dirt. I could just replace a prop, clean the dirt out of the fins with a toothbrush, start her up and go practice some more.
A Saito .72 saved my butt MANY more times than the OS .46 ever could. I can't count the times I was doing something crazy low over the deck and punched the throttle when the plane was getting hairy, and thinking "Wow, the 2 stroke could never do that!"
2 years ago I filled out the R/C report questionaire category "best R/C related purchase within the last year" as "my Saito .72". I still think it was worth every penny. They get stronger with age too! Can't say that about an ABC engine!
So, if you plan to fly a LOT, and you consider the cost of your time, it doesn't make sense to skimp on the motor. In my book, unless you actually prefer the whine of a 2S to the "Harley-esque" thumps of a 4S, there's no reason to use a 2S for 3D. If it's an issue of cost, save that extra 100 bucks you were thinking about for the next plane. Drink less beer. (did I actually type that?) Well, you get the idea. That extra 100 bucks goes towards power and reliability you can almost bet your life on.
Rich, if you do want a used motor, now that the .82 is out, you should be able to get used .72. The power isn't really all that much different ( I find that a friend flying his .82 on 15% nitro is roughly equivalent to my .72 using 30% -- both motors on the same prop, same weight airplane).
ORIGINAL: mikeboyd
... most of us like the two strokes better, because they spool up faster and are cheaper to replace, when we get to showing off and bury it in the dirt.
