RE: G-62 TACH READINGS?
THe 6-10 will run up faster.....top speed a little slower.
I think if you got 6800-7200 with the 22x10 TF it would be enough, but it will run up slowly on a steep pull out. the 6-10 might not change RPM in that manuever.
If the corsair weighs more than 17-18 lbs , vertical will be slow, with the right prop.
