Could you have a blockage in the muffler pressure fitting causing the engine to go lean when the pressure line is connected?
Thats exactly what i thought the other day but upon disassembling the muffler it was completly clean. THe motor is mounted on its side as its on a profile fuse. Do you think that the mufflers possition relative to the tank could be a problem?
