RE: Great Planes Illusion Q's
Thanks for the info.
My intention with the Saito was to reduce weight, and front retract clearance issues. Exhaust is rellatively simple with a 4. I also like the notion of a .60 with a 3 blade. From what I have read though with a larger prop you have a bigger "Disk" in front, which on some manauvers helps to slow the plane down (bottom leg of loops). A smaller 3 blade will provide better wind stability, but run it faster. Not sure how the MVVS quality is, so I was thinking O.S. .60 W/Pipe. The other option is the O.S. .90 W/pipe, but worrried that may be overkill.
Also the instructions are for the illusion, not the Tip, which I also liked, but could not find the kit.
Thoughts?
