RCU Forums - View Single Post - WHAT PROP FOR HIMAX 2816-1220 on Mini Funtana???
Old 07-25-2005 | 10:55 AM
MalaysianFlyer
Default RE: WHAT PROP FOR HIMAX 2816-1220 on Mini Funtana???
Chris, if you have motocalc you can see that with a 10x3.8 you will hit 25A at full throttle. However with this combo, you hardly fly full throttle, and the motor is rated to run 25A for short burst 30s.
If its all out 3D you want then this is a good choice. If you prefer pattern, then the smaller higher pitch prop will work well.
Enjoy
