RE: Pull-Pull Funtana - HELP!
I could use some help on this subject as well.
Im using the Dubro HD 40-90 size pull pull setup and Dubro Super Strength Servo Arms.
1) How do you measure for where the wires exit the fuse?
2) How can you loop the wire in the metal crimp? I can only pass it through once, it seems to tight
Thanks, Chris
