RE: Pull-Pull Funtana - HELP!
Ok I mounted the servo and control arm but I dont understand how to pull a string/cable along the side and bottom from the hole in the servo arm. I also dont know how you could only use one pass through the crimp (even though the crimp is too small for anything other than one pass))
Could you go a little more into detail on your directions?
Sorry I guess Im a little slow?
Thanks Chris
