RCU Forums - View Single Post - Bdavison's E-flite Blade Assembly
Old 07-25-2005 | 08:40 PM
  #52
bdavison
Default RE: Bdavison's E-flite Blade Assembly
The first thing we need to do in trimming is to set-up the swashplate correctly. Its much easier to do this with the head removed from the heli.
To remove the head from the heli.
1. Undo the paddle control frame pushrods from the swashplate.
2. Pull out the shear pin from the rotor head
3. Pull the rotor head off the main shaft.
ID:	301445   Click image for larger version
ID:	301446   Click image for larger version
