RCU Forums - View Single Post - Bdavison's E-flite Blade Assembly
Thread
07-25-2005 | 10:02 PM
62
bdavison
My Feedback: (
1
Aug 2004
3,360
Warner Robins, GA
RE: Bdavison's E-flite Blade Assembly
Well, guys....
In my haste to try to get everything up here....I missed a step.
Cut me a little slack. Its hard to keep everything in order...
Anyway here is the missed step. Insert it right after the "balancing the blades" section.
Centering the flybar.
This should be self explanatory.
1. First loosen the the two allen screws shown
2. Measure and center the flybar so that it is EXACTLY the same distance on both sides of the flybar.
Some people even go so far as to balance the flybar. You can do this if you like, but in my opinion its not really necessary. If later you find that you have some vibration problems, You can check this as a possible cause. As long as the flybar is centered, it shouldnt be an issue.
Reply
Like
bdavison
View Public Profile
Send a private message to bdavison
Find More Posts by bdavison
View iTrader Profile
