RCU Forums - View Single Post - Need Engine Help
Old 07-26-2005 | 05:00 AM
ratedmaxx
Default RE: Need Engine Help
First thing you need to do is buy a temp gauge. Are you using the easy start to crank it or are you using a glow stick? Sounds like your engine is ok. Maybe your easy start its not getting hot enough to ignite the plug. Try a diffrent plug and make sure your getting fuel.
