RCU Forums - View Single Post - Slo-V
Thread: Slo-V
Old 07-26-2005 | 05:31 AM
Glacier Girl's Avatar
Glacier Girl
Default RE: Slo-V
Just like the name implies, it saves your prop. LOL
On an out runner motor the drive end has 2 small bolts that stick out from the sides. What you do is install your prop on the front of the motor, and loop several rubber o rings across the prop to each of the bolts. On impact the o rings allow the prop to move, this reduces the chance of damaging the prop and lessens the force applied to the motor. A similar set up can be installed on the output or prop shaft on a regular gearbox set up.
What it does is eliminate the nuts the mechanically attach the prop to the shaft.
Should have been standard equipment on the Slo-V
