RCU Forums - View Single Post - Rustler 2.5 is cutting out at high speeds
Old 07-26-2005 | 10:55 AM
badz's Avatar
badz
Default RE: Rustler 2.5 is cutting out at high speeds
ORIGINAL: 1BADHD
I have done everything I know to make this thing run right. It idles great, starts easy, runs good to mid range then cuts out and dies at high speed. I replaced fule lines, took apart and cleaned carb and engine and replaced the fuel tank. It acts like its starving for gas. Any ideas?
Cause it is starving for fuel...richen the high speed needle some about 1/8th turn then do a high speed pass if it still cuts out got another 1/8th until that cut out stops.
