With the larger tires, I hope you used the Ultra Lite tires, they are a great weight saving. Hope all works out, anxious to hear how it flies when you get it all done.
ORIGINAL: Mikel-t
OK No Pull-Pull, shorter linkage is better, and thanks for the insight. I will go the MikeBoyd route and see what happens, BTW Swatcop there are 49 pages in that Funtana 90 thread and there are about that many ways to hook-up this plane. I supposed some are hardcore 3D guys that have bashed this plane into something it is'nt cause some suggestions are way-over-my-head. Swatcop I would really like to hear how your maiden flight went. I'm still sticking with lighter is better and leave the 8411 for the rudder only.
MikeBoyd I already added larger foam tires and put 1/2" rubber bushings between the LG and Fuse for extra height and strength.
