RE: Pull-Pull Funtana - HELP!
The Funtana 90 will balance @ 7" with a Saito 100 with all the servos in the tail. Put your battery on a stick up front on the engine box & mount the throttle servo up there too if you are using heavy digitals. Check out the thread " Funtana 90 which engine? " in the 3D forum. I have a ton of pics on this set up.
