RE: Mayhem Engine?
Use any lower motor mount and put a backing plate on it for about $15. Backplate will also stop the small leaks that go threw the one way bearings and crap so you will get slightly more time on a tank and slightly better performance though its hardly noticable. I don't have a mayhem so I'm not sure if you could do this... but putting a bigger flywheel on it would work if it will fit.
