Chokes
I have a new, never started, OS Max .70 Surpass that I am trying to mount in an airplane. The choke assembly is holding the engine far enough away from the firewall that the cowl doesn't fit. The question is, for all you four strokers, how often do you use the choke? Is it necessary to have it operational or can it be removed with no adverse effects? Thanks, folks.
Max
