RCU Forums - View Single Post - 28% Wing Bolts....
Old 07-27-2005 | 09:29 AM
Dangerous Dan's Avatar
Dangerous Dan
Default RE: 28% Wing Bolts....
Not sure what all the wing bolt hub-bub is about.
I am using stock 4mm bolts and fender washers. My BME 50 shakes pretty good at low Idle....52 flights they have never came loose.
The only bolts I ever had an issue with were the two RH cowell bolts....Used a little blue loctite and teflon washers no problems since.
