RCU Forums - View Single Post - Mayhem Engine?
Old 07-27-2005 | 12:53 PM
twigstoy
Default RE: Mayhem Engine?
The vented flywheel will not work with the pro mounts. The flywheel does not go back far enough so the clutch bell will line up with the spur gear. I thought it was just me but my local hobby shop sent 5 of them back for the same reason. The only way I see to correct the problem is to cut down the rtr mounts that you can slide the engine back or forward. This is just my experience , may not be everyones.
