RE: Genesis vibrating/shaking
You say that you are loosing power to the wheels, check the grub screws front and rear. I had big vibrations on mine but it turned out to be a bad foam at the right front wheel. So check your tires and rims, if the tires has been riped of from the wheel you may have destroyed the foam.
