ORIGINAL: propjobbill
Thanks for the answer, the Airtronics VG 400 IS NOT computerized so will a PCM reciever work with it, or only PPM recievers
Thanks For the Help
Only FM(PPM) Rx's will work with your Tx and only positive shift Rx's if you use other brands. Hitec will provide Rx's in both negitive or positive shift and there is one Hitec model Rx as well some others such as a version of FMA have a Rx that is selectable for both shifts. In addition JR Rx's are positive shift.
John
