RCU Forums - View Single Post - Tower Hobbies Kaos?
Old 07-27-2005 | 07:51 PM
EXCAP232
My Feedback: (12)
Default RE: Tower Hobbies Kaos?
Attaching photos of vintage planes including a Kaos, Daddy Rabbit Taurus and QF-III.
Regarding making changes at this point It's time to go for it. You can check the possibility of washout by measuring the wing incidence at the root and the tip. If you set the plane so the wing is at 0 degrees by the fuselage and there is positive incidence at the tip you have washout. If you have negative then it is washin (which is actually worse!).
EXCAP232
ID:	302430   Click image for larger version
